I have the following 893/919 Fireblade Spares for sale:
Engine
U2U on the way...
Hi
I'm interested in a few bits but I need to know which year engine its off as the parts are different for example the water pump?
The bits I'm interested in are the water pump, carbs, rectifier and airbox. So first dibs please!
[Edited on 6/9/10 by carpmart]
Interested in selector drum and forks. what year exactly, and do they show any wear at all, i'e shiny bits or corners knocked of selector drum grooves?
Apologies for the confusion - all parts are actually from a 919 blade, but I included the 893 in the title as some of the parts listed are
inter-changeable.
fluidslvr - ITG provisionally sold to you (U2U on the way).
carpmart - First dibs is yours on the water pump, carbs, reg/rec and airbox (U2U on the way).
Austen - I'm afraid it's only the cam from the front of the selector drum rather than the drum itself. L&R selector forks have only very
slight wear (C is unmarked), but I'll put up a high-res photo of each for you to look at and see what you think.
Thanks,
Mark
Hi Mark
Not received the u2u?
Try now
ITG filter + backplate sold to fluidslvr
Must be some more 919 blade owners wanting spares...
Update:
Both splined gearlever knuckles sold to Joni.
Water pump and original Reg/Rec sold to Carpmart.
All other items are still for sale and will be available at the Stafford Kit Car Show tomorrow (Saturday).
All remaining spares still for sale - I'm open to sensible offers for the more expensive items...
bump
bump
bump
bump for the weekend
bump
I'll take £150 for everything still for sale...
Update
Now Sold:
- 1x ITG filter + backplate (blade carb spacing)
- 2x splined gearlever knuckles
- 1x Water pump
- 1x original reg/rec unit
- 1x Head (complete - valves, shims, followers, head bolt set)
£80 + p&p for everything else listed in OP!
bump
bttt
