I've got a couple of items for sale:
1. Momo Race steering wheel
A Momo Race steering wheel, 350mm in diameter, with anodised aluminium spokes. It is standard Momo fitting (6 hole 70mm PCD)
It is in reasonable condition, though with a few scuffs and some wear. There is one section where the leather is starting to split slightly – this is
not very obvious when the wheel is fitted but I wanted to be up front about it
£20 + £7.50 P&P or collect from Sevenoaks
2. Mazdaspeed horn button with mounting ring and finishing trim
A Mazdaspeed horn button assembly, complete with mounting ring to go inside the steering wheel and an aluminium trim ring with allen-headed bolts (6
hole 70mm PCD to fit Momo, Italvolanti, etc. steering wheels)
Please note that the horn button itself has one of the 3 mounting lugs broken off – my own fault
- which makes the button stick up slightly on one
side, though you might be able to either repair it or obtain just that part as a replacement from somewhere else.
Failing that, you could buy this just for the Mazdaspeed badge to stick on another horn button, or for the steering wheel finishing trim
£5 + £3 P&P or collect from Sevenoaks
