Sylva Riot Rolling Chassis & other bits!!!
roadzterracer - 9/4/12 at 05:35 PM
Hello,
I have for sale my Sylva Riot rolling chassis & a few other bits!!
It was built for the 750MC Kit car series with the 1800 zetec in the back on a BC1 5 Speed box, but these will be removed.
Here is what you will get with the rolling chassis-
Panelled chassis with braced roll hoop
All wishbones
Race Leda alloy front uprights with alloy hubs & modified steering arms (to get rid of the bump steer!)
Front cycle wing brackets
Quick rack & column with helicopter joint, quick release boss & suede steering wheel (180mm ish?)
Alloy tubes in tunnel for coolant
Bespoke rear uprights with adjustment for toe & camber using std sierra rear hubs & driveshafts
Rear cycle wing brackets
Front & Rear anti-roll bars with drop links
4x 13" RS alloys with Yokohama 048R tyres (used )
Full set of bodywork in orange.
'Aeroquip' brake lines throughout
Willwood bias brake pedal with dash adjuster
Willwood clutch pedal
Fiberglass race seat
Bargain at £1900.00
Also for sale-
1800 Zetec engine(130ps) choice of 2!!!
1x Stanwood engineering complete engine with 'control' 750MC camshafts. Very reliable & only done about 50hrs! £650.00
1x Standard 130ps engine. £250.00
Ford BC1 5 speed gearbox (fiesta, escort etc) Complete with Quaife straight cut gearkit. £1100.00
Once I have worked out how to upload some photo's I will get them on here! In the meantime if anyone is interested just drop me a line & I will email them to you.
Thanks,
Dave.
locoboy - 9/4/12 at 06:53 PM
God Damn it! If only I fitted in it, I would love a striker or a Riot.
Good luck with the sale.
roadzterracer - 9/4/12 at 06:58 PM
I could always take out the seat & supply you with a 'foam seat' kit!!
locoboy - 9/4/12 at 07:02 PM
I still don't think it would do it, I have tried them as the shows and they are 'snug' to say the least!
Steve Hignett - 9/4/12 at 07:18 PM
Not that I am trying to sell it for anyone, but you would fit in it Col...
You would need a foam race seat as suggested mind, but I wouldn't have a car with a normal seat in it ever again!
SteveMX5 - 9/4/12 at 08:34 PM
If you have trouble selling and decide to split then I'd be very interested in the bodywork.
matty h - 14/4/12 at 09:11 PM
Is everything there then to make a track car other than a engine and box.
Matty
roadzterracer - 15/4/12 at 04:30 PM
Matty,
To put the car on track you would need the following:
Engine, gearbox, ancillary's(carbs/inj, Starter, alt, managment etc) radiator & hoses, inner cv joints/shafts, fuel tank, front & rear brake calipers, instruments, exhaust, harness.
This is by no means a definative list but should give you a good idea.
The car is currently complete so if you let me know what you want to do with it I am sure we can come to some agreement! (send me a U2U & I will give you my mobile number to discuss)
Dave.
matty h - 15/4/12 at 04:59 PM
How much for the complete car with standard engine and no gearbox.
Matty
roadzterracer - 15/4/12 at 05:08 PM
Matty,
U2U sent with original spec sheet & price.
Have a look at the spec of the complete car & drop me a line.
Dave.
