Heater /demister - as new £18 delivered
sierra diff 3.92 push in type - £40 plus delivery or pick up
Triumph throttle bodies t600 - throttles 45mm and 36.5 mm diameter either side. £50 delivered
bmw k1100 radiator and fan - ideal for bike engined car - £30 delivered
Brembo alloy calipers same size as m16's apart from mounting holes . Need bracket. Alot lighter than m16's £68 pair delivered
Zetec coil pack with silicon leads for crossflow - £20 delivered
Sylva striker pair of green brg front wings - £20 delivered
sorry photo will not upload. send u2u with email address if interested.
All the above need to go. i prefer the phoen so email your contact number if you have any queries.
Thanks for looking
Hi,
I Might be interested in the rad, can you let me have the sizes, any more pics????
Regards
Ian.
Calipers look like Alfa (75) one's fwiw
These are indeed very light!
[Edited on 16/9/13 by rost]
correct on the calipers
rad size 480 (rad core 360mm) by 240 mm. all approximately
Thanks for the dimensions, its too small,
it was good for a k1100cc engine?
I dont doubt it will cool the my engine, its the physical size will be too small for my rad shell, The rad shell I am using is the same as the ones
hanging up.
understand
