Carbs , Ignition and fuel pump Updated
aerodynamix - 27/12/13 at 04:56 PM
For Sale .
Edis 4 unit and wiring for a sigma (zetec se) but will fit any other 4 cyclinder of course , used for testing an engine on purchase . wiring is all there just needs fitting/tidying on fitting .Also comes with spare Edis4 unit too .
DanSt Aluminium intake manifold plate and tubes to weld on , new not fitted .
One set of bike Carbs and Silicone hoses .
One Facet Redtop type Fuel pump .
I'll take some photo's over the weekend , I'm only selling as I'm putting Jenveys and Omex on as the company is now paying for all of the rebuild now
I will split BUT .................
I'm only looking for £120.00 plus post for all of it !!!
Edis units go for £25 each on ebay usually , plus fuel pump is as new and you get wiring with plugs and the bike carbs too , postage to uk adresses is expected to be £10 !!
[Edited on 28/12/13 by aerodynamix]
pekwah1 - 27/12/13 at 08:25 PM
1. will this fit a zetec-e?
2. what else do you need? i assume you will need megasquirt or a similar ignition only ecu?
3. what bike carbs are they?
aerodynamix - 28/12/13 at 11:32 AM
Yes should fit other engines too as this ignition type would have been on a cvh probably when new
Not sure what else you would need I'm not familiar with this type of setup can anyone else give comment please, this came with an engine I bought as a runner , it ran ok revved up etc fine , so I bought it , I then later bought the manifold kit , the bike carbs were originally fitted onto a cut down plastic manifold - which you can have too if you want .
I'll see if I can get some numbers on the bike carbs and post some pictures
Bike carbs are keihin type , believed to be removed from a kawasaki , v595 fd17 serial on the end one
[img]http://[/img]
[img]http://[/img]
obr_technology - 28/12/13 at 03:11 PM
If these are zx9c carbs I'll take it all.
Can you let me know what numbers are on the carbs please?
aerodynamix - 28/12/13 at 09:35 PM
sold subject to payment to pekwah1
STILL AVAILABLE
aerodynamix - 3/1/14 at 06:10 PM
BUMP ANYONE WANT TO GIVE ME £100 PLUS POST BEFORE I EBAY THEM !!
