Ive 4 spark (coil end) lead ends if anyone wants to give me the princely sum of £ 2.50 for them.
They have about an inch of lead on which can be removed so you can fit them on the end of your own leads - should save some money if you are
installing a Ford coilpack for Megajolt/ Edis etc and cant use he leads that came with your distributor setup.
They are the chunkier type of coil ends with the clips on both sides.
Still got these if they are any use to anyone.
