This is the second part of my major clearout to fund a new car. I prefer collection from Derby area but can send bits if needbe.
All prices are negotiable, the more you buy the less it costs.
4 Point TRS Harness, twist type buckle, FIA approved harness, went out of date in 2012 but hardly used. perfect for Trackdays.
£30 or would do for £40 posted (its already packaged and ready to go).
VW (Polo) Radiator. this is larger than the standard locost used Polo Rad' (see pictures) but brand new and has similar outlets.
£15
(I have no idea why the image keeps ending-up upside down)
Sierra Rear disc Brakes. The whole lot, hardly used Ford Calipers w/ pads, discs, handbrake cables and handbrake lever (not pictured). Would prefer to
sell as a whole lot but could split.
No idea on price, perhaps £75 for everything together. Ask if you want something seperate.
Pair of Modified MNR Rear Uprights (not including bearing carriers). These have been modified to take Sierra drum brake style bearing carriers with
push fit driveshafts but have an integral mount for the calipers (for sale above)
They are 7/16 UNF fit, all painted up and ready to go. Maybe £30 for the pair.
Pair of Wishbones to mount the above uprights using rod ends. Should fit on Locost mounts but I will confirm dimensions. These would make a nice
adjustable/disc brake rear end upgrade with the above uprights and calipers.
£10 for the pair or would chuck them in with the uprights,
Mountney Classic Steering Wheel and Boss for Sierra Column. Black Leather outer, Chrome inner with horn push. 12" Diameter
£30
Lower Column Section, fits between Sierra Top section and MK2 Escort Rack and has rubber doughnut 790mm Long
£10
UJ Sierra Upper Column to MK2 escort splined lower section
£5 or will chuck in as a freeby with any other sale!
OMP Helmet, Size Large, full face in white. Has BS approval sticker but will confirm with pictures. This is hardly used and I have always used a
balaclava so its reasonably fresh.
£40
[Edited on 28/10/14 by Doctor Derek Doctors]
U2U sent.
I'll take the rear calipers etc please.
U2u sent
What size is the Mountney Classic Steering Wheel.
Can I have a picture of it please.
Many Thanks.
Len.
It's a 12" wheel, I will upload pics tomorrow.
U2U sent re steering column section.
Tony
Brakes, Rear Uprights and Wishbones and Steering Column lower section are all provisionally sold.
Pictures and dims added for everything except the helmet. Will do that tonight.
Many thanks for the steering wheel info.
Too small for what I would like.
How much for the boss on it's own?
U2U sent.
Hi mate are the harness still available?
Cheers mattie
Cheers mattie
