Looking at a possible group buy of the Blackline LSD’s for English or Atlas axles. If I can get a few orders for these, then I could do the English
diff for £349.95, & the Atlas unit for £384.95, (+P & P in both case, but including VAT) in both cases that's about £40 less than Rally
Design have these at, they are the Professional Traction Blackline units – you’ll pay around £600 for a Quaife, so I feel these represent something of
a bargain if you have a live axle car!
There was some discussion about these back before Xmas
Link to previous discussion
but I felt a group buy proposal was probably not the greatest idea on top of Xmas!!
A couple of people did come back to me about a group buy, so I thought I’d see if we can get one together. I no longer run Furore Products/Cars
myself, (I still do the cars), but have connections there as it’s run by my daughter & her partner, any Paypal or card payments would go through
Furore so you can have a proper invoice & a VAT invoice if required. I requested further info from the supplier re power handling, warranty &
country of manufacture – first I will say upfront these are from China, if that’s a negative for you, then they carry a 12month RTB warranty. With
regard to power handling capability, they don’t have a limit to capacity as such providing they are fitted in a standard Atlas or English diff casing,
in other words if the rest of the axle will take it then so will the diff – obviously they are not covered against such abuse as being run dry of oil
etc.!
I’m actually away on hols for a week from 4th to 11th Mar, but that gives a week or so to get any orders together. I should be available by email
whilst away russbost at googlemail dot com or u2u me.
Outside of the above dates, by all means give me a ring if you want to discuss 07914 258651 or talk to Oliver at Furore Products,
info@furoreproducts.co.uk or furoreproducts@hotmail.com
If it looks like we have viable no.’s for the group buy to go ahead we will need £100 deposit, but stock is readily available at the supplier, so
should be able to get these out quite quickly
I could be potentially interested.
A quick question for the stupid, what's an "RTB" warranty when it's at home?
Also, has anyone used one of these, i.e. do we have any user feedback so far of the product?
[Edited on 1/3/17 by pekwah1]
RTB - Return to Base? Not sure if that means China in this case though
RTB is indeed return to base, but base in this case would mean to Furore Products,NOT China! It just means no one is going to come out & remove the diff for you or be liable for those costs, it assumes you are fitting the diff yourself
It's just been pointed out to me that only contributors can see this thread so can a mod please remove it or add it to the thread under engine/transmission - sorry!
I do fancy one but need some user feedback first.
http://www.mattlewisracing.co.uk/product.php/1905/60/limited_slip_differential_english_axle_ford_cortina_escort
Any different from these, there's only £10 in it for p and p. So £359.00 all in.
I'd say that was the same unit. We can ship for less than a tenner, but I'm a bit gobsmacked by their price, unusual for anyone to undercut
RD by that much, so far as I can see it isn't to have VAT added, but can't see for certain. We might be able to do slightly better on those
prices if there were enough takers but we have just a couple of definites so far
Edited to add that it also doesn't help anyone wanting the Atlas axle of course!
[Edited on 3/3/17 by russbost]
Yes i saw this one as well, i went all the way to check out and can confirm that price does include VAT
The reason the price is so cheap is that the seller has already done a bulk buy from the whole saler. They will have had to buy big volumes up front to offer such good prices.
Guys, if anyone wants to go ahead I need confirmation from you asap, at present we don't have quite enough definites to continue to purchase
