With a heavy heart I have decided to sell of my kitcar, the project has sat gathering dust for to long to many projects time to clear out and focus
on the stockrod racing, plus work has dried up with the current global crisis.
I will add pictures tomorrow when i go to garage.
Parts include
Rolling locost chassis this was not built by me but has been built to a good standard. the chassis has been a fully built car at some point and driven
(not sure if it was track or road) no chassis numbers stamped. Sitting on fiesta rims to keep it rolling
The Rolling chassis has a english axle with a LSD 4.11 diff, shortened maxi handbrake cables going to a mk1 mini handbrake.
Front end is cortina hubs with vented discs(as new only surface rust) and calipers. mk2 Escort steering rack, sierra column with key.
Brand new Propshaft from Driveline test fitted but never had power through it.
Type 9 gearbox painted off white brand escort gearbox mount.
Smiths clocks, Speedo, Water temp, Fuel level, Voltage (used but working)
Omp floor mounted pedal box cable clutch Bias brakes, brand new clutch cable and 2 brake master cylinders.
Nose cone in primer.
chassis has alloy side panels and rear panel these have been riveted on externally, scuttle panel is there but quite cut up and would be better if
replaced. Bonnet is alloy and would benefit from been replaced as the car has had webber side drafts and downdraft so multiple holes.
2 Black vinyl seats
Black 4 point harnesses
Mountney steering wheel
Wide rear arches (need repair)
7inch Headlights
Caterham style tailights.
1.8 Blacktop zetec
I am willing to sell as complete project or happy to sell parts seperately
The back story is I a bought a project seven style kit which had been of the road for many many years however the more I dug in to it I realised how
badly built the chassis was so i purchased the locost chassis as it was far better built/condition, and used the original car to donate the LSD
coilovers gearbox switch gear etc...... The original chassis has since been cut up and scrapped as it should of never been on the road However I still
have the V5c (number plate/vin plate) in my name and sorn, description been kitcar built from various parts.
Will accept all sensible offers either for complete project or parts
Based in Tyne and Wear
[Edited on 6/4/20 by Eddie1978]
Sorry to see you've decided to pull the plug, but understandable. Just to let you know - I would have thought your final sentence re: the v5 will attract a few criticisms on here.
It has not been a easy choice to make but needs must, sometimes sacrifices have to be made, can aways buy another car in the future.
yes i 100% agree the v5 thing is a taboo subject
[Edited on 7/4/20 by Eddie1978]
I believe it was posted here many times that one could legally buy a mini or MGB chassis and transfer everything over to the new chassis and retain the registration.
well not much left now
Cortina uprights with vented disc brakes as new only surface rust pads unused fresh wheel bearings in hubs £100 SOLD
Locost wishbones as new ball joints few years old but never driven £50
Propshaft 32 inch long type9 box to large flange english axle, brand new from driveline never had power through it £50
Steel baffled fuel tank Brand new never had petrol in it £40
11inch Mountney steering wheel with ford boss £30
4 Link and panard rod £30
Caterham type tail lights £20
Mk2 Escort steering rack (metric threads) used but track rod end and inner joints nice and tight feel like new£40
will be some stuff I dig through the hoard will do package deals
[Edited on 11/4/20 by Eddie1978]
Can you send details on the fuel tank?
Size, inlets, position of baffles, fuel filter etc
I will get the measurements for the filler neck and tank sender tomorrow when i go to garage. The baffles are 2 vertical ones to stop fuel surging
left to right. Oh is it right to left mmmmmmmm
[Edited on 10/4/20 by Eddie1978]
Are 4 Link and panard rod still available?
