I知 emigrating so am clearing out the workshop, tons of stuff but some highlights are
2 year old single phase 2 post lift
Loads of brand new Duratec performance parts make stay new from race line or pec, rods, dry sump, pistons water rails oversize valves.
Less than 200 miles old brand new for duratec head with cosworth equivalent 200 Bhp Newman spec cams
Large stainless roll cab / top box with tons of tools.
Parts washer
Hydraulic press
Lots of power tools.
Tiger Avon with brand new GTA body. All new suspension fuel system wiring etc, no engine or box but fitted with a new trans diff.
Several used and practically new clothes helmets.
My preference is for people to come and have a look as it will take ages to list. Unit is near Market Drayton Shropshire.
Mac
07946815058
Are you going far?
Sadly, I can't have any more projects but, good luck selling your bits and pieces
Duratec parts interest me greatly so more details pls,
so does the 2 post lift but Shropshire is to far
No interest in the bits, but GLWTS.
Off anywhere interesting/nice?
Off to spend my twilight years on the beach in Sri Lanka, just spent the last 3 1/2 months building a villa out there.
I値l be back up the unit in the morning and will supply details as requested.
That痴 awesome . Good luck to you
also interested in the duratec parts and/or the head
have sent a u2u
Also interested.
Are you having Locostbuilders discount on your Sri Lanka Villa rooms.
Definately a possibility!
Duratec Parts
New
1. PEC H Beam Rods standard length.
2. Wossner Turbo / superchargered pistons, max oversize, forged
3. Complete raceline Duratec drry sump kit.
4. New Raceline Duratec water rail kit.
5. Alloy charge cooler.
6. King Race Crankshaft bearings MB5442XP
7. New duratec rear crank seal kit
8. Duratec timing chain kit.
9. supertech oversize inlet valves MAEVI-2301D
10. Supertech oversize exhaust valves MAIVN-2304F
11. ARP Head stud kit 151-4204
12. ARP flywheel bolt kit 251-2802
13. Mahle Race bearing, big end, STD VC 1019
14. Retro Ford Duratecc to MX5 gearbox Lightened flywheel with 4 paddle driven plate and high clamp cover.
Used
1. Brand new durateec cylinder head only 200 miles old fited with a pair of Newman Duratec cosworth Cams, Ford/278/375 In & Ford 278/375/Ex
2. Bead blasted and bored block max overboared.
3. at least 3 complete duratec 2.0 litres head assemblies complete but either without cams or with standard cams.
4. Set of Used but only 200 miles old H beam rods fittted with forged 12:1 compression pistons.
5. Boxes and boxes of smaller parts
Just uploading pics now
Also moving on my US Pro Roll Cab and Top Box in Stainless, prefferably with the contents.
See here for Pics of everything mentioned so Far.
https://photos.app.goo.gl/tEPZZLEU7tNmu6F66
Someone asked about Power Tools
Ryobi
1/2" Impact
Drill
Right angle Drill
Angle grinder
3 batteries and 2 chargers
Euber 3/8" impact with 2 batteries and a charger
Dewalt Cordless drill with 2 batteries and a charger
Mains powered heat gun
Mains drill
Also a selection of car polishing tools all mains powered with spare mops, sponges etc
Ryobi
1/2" Impact
Drill
Right angle Drill
Angle grinder
Mains drill
Duratec Parts
New
Used
Snapper
I u2u壇 you my details a couple of days back, can you give me a bell as I知 starting to develope a que behind you!
Now also listed on the Tiger forum, now comes with gearbox and part built Duratec with forged hi comp pistons and h beam rods.
https://www.tigerownersclub.co.uk/forum/thread-14026.html
any pics and prices of the press and the stainless toolbox?
Ryobi
1/2" Impact
Drill
Right angle Drill
Angle grinder
Mains drill
I知 interested in the two post lift.
Could you send details please.
