As above to suit a 1600 x-flow if that makes any difference.
LOL, I would have been the same.
Edit: I can see that you have been doing quite a bit of research on this subject, if you find anywhere to get just the unbuilt kits cheap in the UK
let me know.
[Edited on 8/5/09 by Roman]
I have a spare unused TPS V3 megajolt available complete with molex connector and pins. pm me if of interest.
You have u2!
Sent a pm smac?
Geoff if you sent me a pm I never received it.
Good Morning Roman - I meant that I had sent SMAC a u2.
Nice hijack![]()
I have a used V2 megajolt but it is a MAP sensor version so best suited to a twin choke carb rather than bike carbs or twin 40s.It could be used with
them but may need some experimentation to get a good MAP signal.
It has a wiring loom,edis, coil pack and shift lights and is set up for switchable maps.Although it is the older version it does nearly everything the
later versions do apart from having auxillary inputs for dataloging.You would just need a crank sensor and trigger wheel.
I ran it on my car for a couple of years but am now using megasquirt so no longer required.
I would like £75 for the whole set up.
I have built lots of these and could be tempted to build a batch of the new version if I got a few firm orders
Paul
All sorted.
I got in touch with this guy - martin@millener.com, I have just purchased the following set up from him for just under £110, tell him Jason sent
you.
MJLJ TPS V4, cased, fully built, tested and including a 6 months parts and labour warranty.
16-pin Molex connector pre-wired with 30 cm colour-coded tails matching wiring diagrams on CD.
computer connecting cable, 2m long.
mounting flange set.
CD containing (my own) installation guide and wiring diagram (colour coded to the tails on the pre-wired Molex connector).
Great bloke who knows what he is talking about.
