loom conectors
beaver34 - 6/12/09 at 08:54 PM
after some wiring loom conectors if anyone has some kicking around before i nipp toa scrap yard and cut some off, as many pins as poss
thanks
rusty nuts - 6/12/09 at 09:38 PM
Have a look at Vehicle wiring products website for multiconnectors or try your local motor factors , they should be able to supply Durite connectors. You will need a crimping tool for non insulated connectors
dhutch - 6/12/09 at 10:17 PM
I ended up buying some AMPS superseals off ebay for my loom.
- Cheaper than anywhere else could get them and waterproof.
beaver34 - 6/12/09 at 10:22 PM
ive had a look on those websites, ive allways found standard manufacturer stuff alot better quality to be honest, the quick relese ones on demon tweeks looks good though, but come at a price
Macbeast - 7/12/09 at 10:49 AM
I wouldn't use second-hand / scrap connectors as they're likely to be unreliable with age.
beaver34 - 7/12/09 at 06:15 PM
the ones i have at the moment are like the cbs ones, and after 4 years there crap, the other loom parts from the ford looms i use are perfect and waterproof still after longer
