Hi guys,
Does anyone have a tube notcher they fancy selling? I need one for notching 2inch pipe for the roll cage in my tr8.
Drop me a pm or post below if you have one you will part with!
Iain
locost option?
http://www.pirate4x4.com/forum/showthread.php?t=542960
[Edited on 21/12/11 by jossey]
Thats the best locust option I've seen yet
Possibly a solution! Although I would still take a notcher if some one had one going for handy money!
If it's only to do a roll cage download tube notcher:
http://www.shedworks.eu/links.html
Thanks mate..
It's a full weld in cage for a rally car so there will be a fair bit of cutting to be done.. Alot angle for roof brace, door bars and other cross
members!
I made something like that for my heavy duty pillar drill (50 years old huge) the teeth dragged and it bent the morse taper shaft that the chuck sat
on just after the threads.
TBH its not worth doing like that, as the drill bit to support is quite distant so simply not rigid enough, I suspect a weak piller drill will bend or
just stall.
Frots was the cheapest ive seen recently, about £65.
Originally posted by Benzo
Hi guys,
Iain
Missed out on that one!! Anyone else got one they want to sell??
Or when you have finished Iian
Cheers Scott
Anyone else???
