hi there
looking for a replacement master cylinder...i think mk2 escort ? part number on side is 64677686.0261g
anyone out there got one in there garage ?
thanks
striker-4age
no mate there is no band with the part number
Can you put a pic on? Was this for an Escort with or without a servo? Do you know what the split is front to rear?
I may be able to help!!
Colin
hi colin u2u sent
thanks
striker-4age
Hi -
Suggest you try finding Fiesta XR2 non-boosted mcyl 74066105. For external ID, casting no should be 74660186 or 74660205. These are 19.0mm bore; check
if this will be sufficient for your caliper requirements.
hi mate
is the xr2 one a two pipe cylinder ?
thanks
striker-4age
hi again
i need one with 2 outlets only : 1 for front brakes and 1 outlet for the rears. is this what the xr2 cylinder has ?
sorry for all the questions
thanks
striker-4age
Hello Striker,
Been away over weekend, & just picked up your posting. AFAIR the XR2 mcyl may have 4 outlets, because vehicle has X - split brake system. This
means that LH front is connected to RH rear, and RH front is connected to LH rear. Ford used the mcyl to make the connections, to save themselves
having to spend money on extra connections.
Should you need to, unwanted ports can be blanked off, either with a bleed screw, or by using a sutably-sized ball-bearing, locked in place with a
spare tube nut.
