Greetings Folks,
I'm after some MX5 bits for the next build. I'll be away until the end of the month, with cash ready next month. The bits I need are;
Instruments/clocks with plug and as much loom as poss.
MK1/2 steering column (upper and lower) with switch gear and ignition barrel/key, plus plugs and loom section.
Does anyone have any of the parts about, before I start on the breakers yards.
Regards Dan.
It's worth pointing out that if you go mark 1 or 2, you have to stick with that choice. The column switches are different, therefore have
different plugs on the loom. They also bolt onto the column differently, so you can't mix a mark 1 column with mark 2 switches or a mark 1 loom
with mark 2 switches etc. That's not to say it cannot be done, but you'd be making life unnecessarily hard for yourself. Guess how I know
this??!!
Lee
Cheers Lee. I waa hoping for a complete column to avoid that issue.
Atb Dan
I've got a mk1 cluster you can have for postage and a small number of beer tokens.
Might still have the connectors, will have to have a rummage. Let me know if you're interested.
