Can anyone help, or know anyone who could machine a brake disc down in diameter? my lathe just isn't big enough.
I need 1 motorcycle disc reducing in diameter from 295mm to 280mm.
Sheffield area would be good.
Cheers.
Claretoo isn't exactly local but the last time I was round (couple of years ago) she had a gap bed lathe & had machined flywheels.
May be a backup option.
Bolt it to a dril and get the angle grinder out
As above, mount to a wheel hub and use an angle grinder - I've done this to take a few mm diameter off my front hubs, works fine if you don't mind a bit of unevenness.
Yes I've used a spinning part, spinning grinder process a couple of times to produce lovely round items - works quite well. Work holding is a bit difficult at times though.
Local machine shop will easily sort it.
Cheers guys, I had thought about bolting it up into the swing arm and seeing if I could rig a cutter up, guess I could annoy the neighbours with an hour of two's angle grinding.......
I'm finding it harder and harder to find a local machine shop willing to do stuff for cheap prices - they all want reasonable prices for half an hours work, damnit.
Hi
I have access to a leath at work I could do it for you.
But going away tomorrow not back till tuesday.
I'm in Sherburn in Elmet east of Leeds towards Selby.
U2u me If I can help
