Duratec Main Crank Bolts Wanted
itsawindupuk - 5/9/14 at 03:42 PM
Hi guys, im after a set of duratec crank bolts, second hand is ok so long as they haven't been used more than once.
Many thanks
Adam
Mr C - 5/9/14 at 06:37 PM
I've got a set of ARP mains studs which I fitted, then removed because they got in the way of the raceline sump and baffle plate arrangement as they are studs and nuts rather than bolts. They haven't been in a running engine and are essentially new.
£116 from Burton Power
Linkage
If you want them I'll let them go for £65 (plus postage if you are not picking them up)
[Edited on 5/9/14 by Mr C]
itsawindupuk - 5/9/14 at 09:26 PM
If you can give me a little time then SOLD!
Mr C - 5/9/14 at 10:06 PM
No problem, if I get bored of waiting I'll let you know..
itsawindupuk - 5/9/14 at 11:31 PM
thanks
