as per the title, preferably the original type sylva did and raw type will probably be the same. Also any other crossflow parts weg. lowered sump, lightened flywheel, rear cranksahft seal, sylva crossflow mounts. please mail with details
Originally posted by striker1660
....Also any other crossflow parts eg. ....sylva crossflow mounts. please mail with details
Thanks Dick, will skip as i am not sure the base is right for the striker.
This is what I have. I will be cutting off back to the chassis rails.
I have a pair of crossflow mounts from my car, it's a 98 live axle chassis.
They've been stood around for about 12 years and have got a bit scabby, so want a good cleanup and repaint.
They were paired with a 4spd escort box, i'm not sure how much the 5spd would alter the positioning.
https://www.dropbox.com/sh/68jzmzn36m6hknp/AACTPsO0gFKZVsFRiCUcuSWaa?dl=0
I have a hi-flow twin 40's inlet manifold, it has had a trim on 2 mounting lugs where i had it bolted to an adaptor on a zetec.
I have a matched pair of dellorto 40's that are in good condition, they have not been used since rebuild, i replaced anything that was required
at the time. They're jetted for a tuned crossflow, i'll have a dig around and see what the jetting was exactly, iirc they're 36
chokes.
I also have a cheapo 4-1 exhaust manifold in mild steel that was modded to side exit, i suspect you probably are looking for something a little more
aesthetically pleasing.
If anything is of use let me know.
Dave
