Hi there, anyone got a cheap alternator and bracket for a 711 crossflow.
Cheers. Andrew
I may have a spare bottom bracket , but I don't use the top one, as it fits to the water pump, and is fragile
So I use a threaded bar off the hole in the top of the block just under the head at the front
steve
[Edited on 6/5/18 by steve m]
Hi Steve, It's the bottom bracket I am after if you can let it go - just PM me with some details and I'll send you some money and details
via PayPal.
Thanks for the tip about the top bracket.
Cheers. Andrew
I will go and find the bracket first !
Which alternator is t you need?
Mike
Hi Mike - it's an LRA103 alternator.
Thanks. Andrew
Ive found a spare top bracket, but no lower one at the moment
steve
Hi Andrew,
If you want a new one at cost they are £50.28 including VAT and delivery.
Mike
Thanks. Andrew
New alternator supplied by Mike (aka starterman). First class service and packing - genuinely highly recommended so massive thanks there.
Still looking for the elusive bottom bracket if anyone has one knocking about.......
Cheers.
Andrew
Two links below
The second one states Crossflow in the main listing
https://www.ebay.co.uk/itm/mk1-2-escort-cortina-capri-711m-crossflow-alternator-bracket-3036E-S010039A/232756496922?hash=item36315e4a1a:g:nnAAAOSwAJFa
7A~G
https://www.ebay.co.uk/p/Ford-Leyland-Alternator-Adjusting-Brackets/1809810374?iid=222944970180
May be of some help
