Wanted 893/919 fireblade sump baffle .
Hello Craig
It took me literally 10 minutes to make one, lay the sump on a bit of aluminium sheet, scribe around it and drill the holes then cut out the blank
with a jig saw.
A few holes needed for the filter, oil bypass and to return oil and it's all done, plenty of images to google for ideas on the holes.
Craig, I have a baffle , but it’s within a billet sump on a 8,000 mile engine. Maybe not what your after but their getting harder to get hold of now if you ever need a spare.?
Try ab performance he has some cheap enough.
