Anybody know where I can get these three bits from?
Cheers and thanx in advance
Rich
Try Burton Power as a first port of call
And your local Ford dealership as another....if they still stock bits for that engine....
I may have some. Ive certainly got the manifold. Ill have a look in the garage tommorow
Are you sure you need all three ? The large on on the right is for a Vacuum assisted brake setup. I'm running a weber DGAV carb and I'm
only using the large water connector in the middle.HTH
Originally posted by ayoungman
Are you sure you need all three ? The large on on the right is for a Vacuum assisted brake setup. I'm running a weber DGAV carb and I'm only using the large water connector in the middle.HTH![]()
do burton do the middle one (water?)
If you still need them I can sort some out this week for you. I have a couple of manifolds with them on, I just need to find a minute to take them
off.
Let me know.
Thanks guys, I think smac has got me sorted, so thanks everyone.
Yes I would only the need the water elbow as I'm putting a dgav, case of asking before engaging brain
Thanks again
Rich
