In the true spirit of this site - how have people got on with individual scales to set corner weight?
Was thinking of getting four of these.
200 KG LCD Digital Electronic Personal Scale Glass Bathroom Weighing Body Scales
I found that digital scales time out
I used mechanical Doctor Scales from Argos, about £20 each
Heavy Duty Industrial Digital Postal Scales Max Weight 200KG 440lb LCD Backlight
I suspect these would be safer.
Also if doing it really cheap buy 1 and do each corner at a time.
200 KG LCD Digital Electronic Personal Scale Glass Bathroom Weighing Body Scales![]()
Originally posted by loggyboy
Heavy Duty Industrial Digital Postal Scales Max Weight 200KG 440lb LCD Backlight![]()
I might be wrong but surely if you are weighing one corner at a time you will be transfusing weight to the other wheels as you will have raised one corner up shifting the weight giving an in accurate reading
(Unless you raise each of the other wheels up to exactly the same height, in which case you may as well get 3 additional scales)
Just use 3 blocks of the same height as the scales and do one wheel at a time![]()
And 1 scale and 3 blocks will be dead accurate
where as 4 scales could give 4 different readings.
(Did mine with the One Scale Method)
I bought two sets of really cheap mechanical scales - £4 each I think, and used one under each wheel. They went right off the scale but I marked them
with pen and checked on one side and they read about the same, so then just a question of adjusting the shocks until the reading were the same on each
corner.
Probably not very accurate but close enough for my purposes.
When adjusting each corner, don't you need coilovers with an adjustable perch at both ends of the springs?
As far as i can tell, Protech only have a lower one. Won't this just mess the ride height up when balancing the weight?
No only need one "perch" adjustable. The process is iterative, there is an order that helps, something like add a turn to one coil over and remove a turn form the opposite coil over.
The iterative nature of this means having 4 scales would be quicker in principle to adjust but at x4 the price...
Dan
[Edited on 8/3/17 by Bluemoon]
Quote
"When adjusting each corner, don't you need coilovers with an adjustable perch at both ends of the springs?
As far as i can tell, Protech only have a lower one. Won't this just mess the ride height up when balancing the weight?"
It is possible, and indeed the target to get the front ride heights within 1 mm, AND the corner weights to within 1% of each other
This ensures that the car reacts to the steering and weight transfer the same whether turning left or right.
The fine tuning adjustments are carried out at the rear.
As mentioned above the weight moves diagonally across the car BUT less 'fiercely' than adjustments at the front.
With an an offset driver, this usually means that the Right Rear wheel caries extra weight, and unladen, has a slightly higher ride height.
