Im looking at getting myself an air compressor, nothing to expensive to start off with, prob second hand with a 50L tank but not a big motor or big
displacement pump.
now if i end up with a compressor unit with only a 1hp motor but with a 50L tank and want to run air tools that require more air than the pump can
deliver,
i guess what i do is let the pump build up the pressure in the tank and then use the tool with the air in the tank and then when the air has gone i
would have to let the air pressure build up again before i can use the tools again.
Is my thinking correct?
And i just guess that doing it that way it will just take longer to do jobs.
Many thanks
Tommy
you are better off with a smaller tank, and a larger compressor
it wont run as long for the same job...
i find the noise of my compressor very annoying, so the less it runs the better
You'll be surprised and frustrated how quickly the air runs out!try to stretch as far as you can for the pump.
(no hijacking intended but what engine oil do you use in the Nissan motor)
chris
Not dumb at all. Some small compressors can only manage 100psi which is less air in the reservoir - the bigger the reservoir and the higher the
pressure then the longer you can work without the motor kicking in.
I would buy one and buy the biggest you can afford. Direct drive compressors are really noisy compared to belt drive. After a while the noise will
drive you (and your neighbors) mad.
That's correct. I've got a 40 litre compressor, but added an additional reservoir of about 15 litres. It's alright for doing most jobs
using air tools on the car. Stuff like air ratchets use loads of air, so sometimes you've just got to wait for the pressure to build up
Cheers Eric.
I dont know what oil im running in my engine yet as it still has the same oil that came in it (it came from a tricked out 200sx s13 that was used for
drifting so its gots some good stuff in there)as it had only done 2000miles before the engine was removed and ive only done about 250miles.
When i do replace the oil i will go over to the sxoc forum as there is a list of which oil to use.
the compressor ive found is one of the 'silent' ones (edit: the type with the 2 motors sat on top of the tank) that is about 40db so not too
noisy and not that expensive, i dont know how much i am going to be using air tools so dont want to spend to much yet
please keep the comments coming
tommy
edit again: this one goes upto 8 bar
[Edited on 12/10/10 by tomgregory2000]
Personally I don't like the noise compressors make, and the space they take up.
I bought a 3HP V twin compressor and it only just keeps up with my die grinder.
Neil
I would agree that a 3HP with a big tank is the best solution for car building. I have a small 2HP compressor and a 1.5 HP belt drive with a huge tank
(it is an antique!) neither can keep up with an air drill or die grinder and even air shears that a re a complete boon for cutting ally sheet get the
2 HP running after less than a minute. When you get to spray painting again a consistent air delivery is vital, if you want to use an air fed mask
these also require tons of air. I have my 2hp for the mask and the 1.5 hp for the gun and cannot run very long before the pressures drop below spray
pressure, that is annoying if you are trying to cover a big panel or a big area.
There was a good review in one of the Practical Classics some months ago looking at 3hp 50 litre compressors. I can't remember which was top but
i think it was around £270 which would be money well spent. If I had the chance I would in retrospect have bought one at the beginning!
Caber
I also can't be doing with the noise, so i built a little shed/hut thing just outside the garage for the noisey beast to live in
[quoteI don't suppose many people actually enjoy the noise and space issues, but the advantages of having a compressor and air tools far outweigh these snags.
A compressor is one of the first things to have in a workshop. Often worth having a small one for constant air and then a bigger one for when you need
the CFM to run tools and blast cabs etc. I have a blow gun on my mill and one by the lathe all the time, (just don't aim it at the slide ways!).
You won't know how you got by without one!
get the biggest you can afford.
when i was hobbying at home i used a 3 hp single phase belt drive compressor, when i set up doing it for a living i bought a 500 quid 10hp hydrovane.
I have now sold the 3hp and 10hp and bought a 7.5hp piston compressor brand new as its business critical and i wanted something 100% reliable
