Can anyone tell me the dimensions of the standard roadster scuttle.
Just the length at the back and front of the scuttle, the width and the height.
My chassis design is different and im wondering if i can make it work.
Thanks, Mikkel
i,ve got the book with me, hang on & i,ll get the dimensions you need
andy
the front width( bonnet end) is 100.6cm
the rear (cockpit end ) is 111cm
the width between the base( resting on top rail of chassis) is 36cm.
the height is difficult to give as its to do with how you curve the ends to suit your own bonnet,
hope that helps.
andy
many thanks andy
no prob, hope the info helps
andy
