I have bolt on arches on my Striker and may need to space them out from the body possibly up to 10mm. Question is, what can i fill the gap with without using mastic ? It is a track car so doesnt have to be a pristine fit, but would some sort of dense foam be suitable ?
Mdf or ply. draw around the arch and cut it out with a jigsaw.
You could cut the arch and glass a band in.
Meant cheaper than 10mm ply
I am sure Woolies will have something
http://www.woolies-trim.co.uk/
mdf and gaffer tape looks the way forward then.
