I wonder if this would fit over a locost 7?
I have asked the manufacture for details of the wheelbase and costs (I think it is around £800).
£800 seems cheap for a quality body shell!
Its only £58 - read the advert....
More details and pictures here http://www.pistonheads.com/gassing/topic.asp?t=1212189
Pretty little thing.
According to the drawing it's £58 0s 0d
That might be a bit out of date though
Edit...must type faster.
[Edited on 16/9/13 by adithorp]
I have a mk2 original shell and one locost rolling shell unfornately the locost is 93" and bit vs the mistral which is designed for 90". So
we ar enow going to cut the shell in half and also length ways as at some point it was narrowed. You will also have a discrepency in the cockpit front
vs the the typical point were the dash was sit ont he chassis.
Effectively you would cut infront of the leading edsge of the cockpit and move back the whole section to aligh the back end and then add in the
3" section in between.
Havent cut yet will be in due course. Need to shift pheonix first.
