As per the title really! What's best to use for body parts, side panels etc and what's the difference in the numbers for sikaflex 221, 521, etc
Both are pu glue sealers sikaflex is better in my mind but more expensive
having said that we use tiger sealer at work for gluing alloy panels on buses and never had a problem
122 is the one to use if you go for sikaflex
jacko
When i was building a camper van, most of the people of the forum swore by Sikaflex.
Saying that, i've just bought Tigerseal for job on the Indy...
Both are no doubt up to the job.
Ive used sikaflex and also toolstation's PU adgesive, which is a lot cheaper
http://www.toolstation.com/shop/Adhesives+%26+Sealants/d180/General+Sealants/sd2350/Polyurethane+PU40+Sealant+300ml/p67949
Either will be fine. Both stick like s**t to a blanket. Both get on your fingers and won't come off
With regards the sikaflex I'm sure it's the black 221 I've always used. Tiger seal on the current build.
anyone tried ct1 ?
Originally posted by rash12
anyone tried ct1 ?
Originally posted by sdh2903
Either will be fine. Both stick like s**t to a blanket. Both get on your fingers and won't come off![]()
Thread resurrection I know, but helpful to keep the info together I thought...
How many tubes of PU am I likely to need for a complete build of a 7? I am expecting to bond the tunnel, floor, bulkheads and body panels...
