I have an angled aluminium passenger footrest. Has anyone any links to a means of making this adjustable? rather than moving the seat back and
forth?
Regards Jon
A couple of slim seat sliders?
Failing the seat slider idea you could try some holes in the car floor, holes in the foot rest and metal pins dropped through secured with R clips
under the car. If you ground out you'll risk damaging the pins and R clips though and may make them difficult to get out.
On balance I'd probably stick with using the adjustability of the seat if it's already there.
My Skoda has footrests for the rear passengers, it's attached to the floor by velcro, and it works perfectly fine. I'd be tempted to do similar in your case, a couple of velcro strips on the floor and the matching strip on the footrest. Velcro is surprisingly strong when attached to flat surfaces and subjected to lateral forces.
You can get velcro-like stuff made by 3M - both sides are identical, but the grip is amazing.
3M dual lock
It comes in tapes, pads, etc.
3M dual lock
Originally posted by Charlie_Zetec
I can confirm this stuff holds - have used it previously on headlight protectors on motorbikes, as well as securing a GoPro (with a backup tether, before anyone suggests being unsafe!) to a helmet. Never had anything come adrift!
3M dual lock
