hi,
does anyone know if the aston/monza style filler cap will pass SVA as i would like to fit one of these instead of a flush fitting one
AFAIK most of them wont. Its dependant on the radii on the edges of it. I dont have a manual to refer to so I cant tell you exactly.
One option is to fit one within the boot area for SVA and afterwards refit to where you want it.
Check the rules around edges below the rear panel (inside boot area) tho. before doing this. You may need to fit a cover.
Why not just go for a sVA compliant aero style one - look better imho.
