could someone do me a favour, what distance does the catch and the hook have to be apart for a good tight fit, is there a recomended distance ?
could someone measure theres for me before i go mad please ? eg hole to hole.
[Edited on 3/5/06 by graememk]
See this link..
http://www.locostbuilders.co.uk/viewthread.php?tid=43681
and the spec sheets here
http://www.southco.com/product/class.aspx?cid=7420
thanks reman, i must of missed that thred.
You're welcome.
If you do like Donut with foam, then you could fit without then benefit from the extra tension with the foam.
No foam for me, hence the dry run on a block of wood.
You'd be surprised how much difference 1mm makes.
Colin
She preferred my stamina!!!!
Or did she say stammer
Ps:I'll apologise upfront David,I'm sure wife is a very nice and correct lady really.
Strangely enough I have rubber bonnet catches as well!
Cant remember how I did mine,trial and error probably,or just a good guess!!!!!!!!!
