Hi all - I am using a 2 litre zetec in my build and plan to use the original injection system, so anyone know what petrol pump I can use, the book
calls for a regulated pressure of 2.1 Bar (about 30 PSI in old money!), but does not quote flow. Has anybody done this and what did they use.
I aim to put a modified airbox on so it all fits under the bonnet.
i had three second hand vauxhall bosch out of tank pumps (cavaliers) and they all failed so ended up buying a new one from fse. You will need a fuel
pressure regulator to set the fuel pressure to what you quoted.
Ned.
I use th VW golf GTI fuel pump. It has a built in swirl pot. Dont know what the pressure is though.
