hi all
any idea's on the best way to fit the loom into the tunnel i was looking at the self adhesive backing for cable ties do they do them you can
drill on instead if sticking
cheers
colin
Spiro wrap and split conduit then secured with P clips on mine. Rear loom uses connectors to keep it separate from the main bit.
I protected the loom with a sleeve then p clipped and cable tied around the tubes. I would suggest you use something a little stronger than the
adhesive mounts as it can be a hostile environment in the tunnel what with water oil etc. And if it breaks free the prop is sure to wipe out your
wiring, and it is not easy to get in and replace.
[Edited on 1/1/09 by Howlor]
I wrapped my loom in plenty of self amalgamating loom tape and fixed it with cable ties using the rivet on type of saddle from pole-volt.
You could look at using trailer wire (ie the 7-15 core type). It keeps it all neat and easily understood, as each wire is numbered.
You can get cable ties with a small mounting hole to attach it with a bolt/self tapper/rivet. I think I bought mine from
here....
How about these click me
you have to rivet, they will not accept stuck on pads
cheers guys
cheers
colin
never use stick on cable tie fixings as the sva a man will not pass it use p clips best bet....
quote:A better option, which I think has been mentioned on here before (in the link above) are "Screw fixing cable tie bases". You can cut the tie off and replace it and is also a permanent fixing.
You can get cable ties with a small mounting hole to attach it with a bolt/self tapper/rivet. I think I bought mine from here....
I nearly failed my SVA 'cos the inspector thought I'd used stick-on pads everywhere - I had to demonstrate that I'd put a rivet through
most of them. He let me use a couple of tie-wraps where I wasn't able to use rivets. I'd use convoluted tubing to cover the wiring, and
P-clips to fix it safely.
Don't forget to keep the fuel pipe, electrics and brake pipes well spaced apart - none of them should be able to touch any of the others, even if
pushed hard. Also, remember that there's a propshaft spinning in the middle of it all...
hi all i should have said that i did want to rivet them on but couldn't find where to get them from a trip to my local screw-fix in the morning
cheers for your input guys
cheers
colin
