Hi all,
I've seen that many people on here have had problems with their blade engines and Koso clusters. I've tried a few different ways of getting
the revs right, I wanted to know if anyone has actually got a solution for this? I find it hard to believe that nobody has managed to get these two
working correctly.
Can those of you with a blade engine also watch THIS VIDEO and tell me if you
agree with the readings from the rev counter, It looks about right if maybe a little high. On this video its set to a 12 cylinder 4 stroke engine.
Definitely looks like the rev counter is reading high
Phil
agreed, but functionally seems ok (ie its moving!) its not too high though, they idle pretty high dont forget
Also agree it looks as if its over-reading. I doubt it went above 4-4.5k
