i need a good range of toggle switches (to go in the exempt area of the dash)
really need somewhere with a really big range. double pole flasher switches are what i'm struggling to find. VWP don't seem to have what i
need
http://www.cbsonline.co.uk/switches-302-c.asp
Anygood ?
not sure the range is quite wide enough there either
i did draw out a diagram of the switches i need, seem to have lost it now...
will have to have another go at it
ooh, actually, just had another look, seems alrightbut the only one i'd be missing is a double pole flasher switch. has to be double pole coz it
needs to operate the solenoids for the flaps in the lights to switch to main beam, and the lights itself
[Edited on 2/3/09 by blakep82]
Sounds like you want a on-off-mom switch (mom meaning momentary).
Farnell sell these, which aren't cheap but are IP68 so water/dust proof.
http://uk.farnell.com/jsp/level5/module.jsp?moduleId=en/213148.xml
