Which 2 relays are they and where are they located, the 2 relays that are used in the ignition setup using the esc2 method
Go on then... give us a clue what you're onna-bout???
There are 2 relays that are used in the ignition system within the esc2 setup, i need to know where they are located at in a sierra
Sorry, now you explain I have absolutely no idea to what you refer.
We didn't use them... left them where they were and used a bike engine.
I give up too.
What is esc2 ?
esc2 is the name of the ign module used in some sierras. The relays will be in the fues box. You will have to follow the wires back, or work out the
code.(if there is one)
