Sorry another wiring question.
How do i get the revs signal from a 2008 R1 to my acewell 3252 digidash?
From what i can tell from the manual i need to connect the 1 cable to the ignition coil? But which wire and which coil?
And then need to input the revelutions per second? The choices are 0.5,1,2 or 3?
So can anyone help me with this?
Se the yellow wire with black trace from the ecu that feeds the bike clocks
thanks, i will give that a go.
can anyone tell me how many revolutions per signal/pulse there are though, so i can have it set right?
think it's .5 because it's wasted spark. you'll soon tell anyway if you get it wrong, My R1 ticks over at about 1000 rpm so acewell
tacho if on wrong setting will either read 500, 2000,3000, so easy enough to alter if set wrong .
tony
