I've checked the usual places but can't find anywhere that sells rear fog lights with the correct markings. I have found some that are
'E' marked but none with required 'F' any suggestions?
I did search but couldn't find anything.
Bought mine from a local motor factors (square trailer type). Fully F marked off the shelf.
95% of the time an E marked fog will have the B or F marks also.
Don't want to risk mail order and get something that isn't correctly marked. Will try local factors next time I get a weekend off.
Mine came from here
http://www.s-v-c.co.uk/category/fog---reverse-lights/
I have the same problem. I got one from Bolt on Bits and it turned out to be E marked but not F marked. I would be interested to know if anyone has
used an e-bay supplier that has been proved to sell F marked ones.
I've looked, but the adverts don't mention F marks and I don't want to risk buying another dud in the hope that it happens to have the
right markings. Rather annoyingly they all say 'E' marked and IVA compliant.
Trying to avoid the ones that hang off a bracket
Hi
car builders solutions sell the fog lights & the angled lamp housing
round or square, & cheap+ E&F
The fog light must be mounted horizontally.
Doesnt matter a bout the reversing light.
good luck
René.
The face of the fog light must be vertical
I have one of the square type that went through IVA and subsequently fell off after the test that I'd like to sell rather than let it take up
shelf space.
£5 posted?
i get most things from kit spares, as they are attached to the factory that supplied my kit, always an excuse for popping in when Im up there and
spending dome money!
kitspares foglight IVA compliant
edited to say kitspares is £9.62 posted
[Edited on 23/1/13 by AndyW]
Have bought the one davidW offered. Thanks for the advice all.
