My Zetec engine came with an LRB00344 Lucas alternator that appears to be from a Daihatsu.
It's the 2 plug type that looks like this : Image
I've looked through all the usual suspects.... where's the best place to get a two pin plug shaped like this, short of going to a breakers
yard ??
I could use a couple of space terminals, but I'd prefer the proper plug.
Incase anyone else is also looking for this, here's a link to how to wire it up Linky
Link
[Edited on 17/12/13 by Barkalarr]
Looks like an AC Delco plug. very common used on lots of things, will look for you in a bit as I'm in work
AC Delco PT705 is the part.
Not got much time to look I'm afraid but here's one to get you started
http://www.ebay.co.uk/itm/12126434-PT705-WINDSHIELD-WASHER-PUMP-CONNECTOR-/360400997645#ht_217wt_725
Chelmsford Auto Electrical in Witham are helpful with those sort of things - got my alternator and matching plug from them.
Its all abuot spade connectors!
