hi
any reviews on the above they seem to do nearly everything
Im looking at getting one as Im not bothered about warning lights aswell etc
ta chris
I have one, it's a very cool toy.
I'm using a Veypor VR2. 'Tis a good bit of kit, with several functions:-
Tacho, speedo, distance travelled, gear indicator, shift light and g meter.
They also regularly update the software adding new features. They have just added a virtual fuel gauge (with MPG, range etc) and a servicing timer
which you can programme to come up on hours engine run or miles. Last update also added 4-5 different options on the display.
However it does not monitor:-
engine water temp, oil temp, oil pressure, volts, amps, etc, so you would need additional dials to cover them.
You also need the regulation warning lights, indicators, hazard, brake fluid etc, so I have a bright6 too.
I always intended fitting the 3 gauge set from NFAuto once I'd passed the SVA, but have fitted some others off ebay now.
It does however have some cool features though, data logging, 0-60 runs, staged 1/4 miles, 50-70 timer, 70-0 timer.
The V-Max feature on mine seems to be broken, either that or perhaps I picked up one of Darrens missing magnets, cause mine was showing 125 on the
return from Stoneleigh.
HTH
Mike
ok wicked does it measure a not far out bhp aswell
Will not using the R1 clocks be a problem? I'd read somewhere that a few people had problems because there's some computer wizardy in the
clocks that are required (and some people saying the opposite).
I'd be interested in fitting a VR2 to my own R1 Indy - looks superb and nicely sized as well
no sorry mate I now have a stripped out metro VVC
and was looking for a nice dash
the r1 clocks with a white dial look fantastic I think
Originally posted by Guinness
The V-Max feature on mine seems to be broken, either that or perhaps I picked up one of Darrens missing magnets, cause mine was showing 125 on the return from Stoneleigh.
Nice one Mike - well remembered. quote:
very good piece of kit also has a vertual fuel gauge
looks good flush fitted takes a bit of work though!.jpg)
looks good
can it not be screwed apart in half then jigsaw a hole in the dash then put the the thing back together with the dash in the middle
