im using the 2004 zx12r loom with toggle switches
im struggling on the lights
should i use
a) on/off/on switch for side and dip and a single on/off for main
b) use on/off/on for dip and main and on/off for side??
thanks in advance
Option b is te best, so you can switch on he side lights first,
After that you can go to dim lights or main beam.
Daniel
Daniel
an off/on/on switch would be easier but i already have the others
many thanks people
by the way for sva and mot the side lights have to be able to be on without ignition on
didnt know that thank you
