Hi all can you run a 6 cylinder skyline engine on a megajolt ? with bike carbs
Jacko
With an EDIS6 of course
www.trigger-wheels.com will sort you with an edis 6, trigger wheel and sensors etc. seems to work out a lot more expensive than 4 or 8 cylinder kits
though
Surely you'd be better off running a Megasquirt on a skyline?.
Then you wouldn't need the rare(er) EDIS 6 as the MS can have onboard coil drivers and presumably you could use any 6 cylinder coil pack.
Yes it is just the edis and coilpack that needs changing to 6 cylinder version.
I have an Edis 6 avaiable as well as some built up Megajolts if you need one,but as suggeted you may beas well to go for throttle bodys and megasquirt
but it is more involved than a bikecarb installation.
Paul
Paulf
What are the cost of the Megajolts ?
U2U if you like.
The ones i have are tps versions and are built from official kits i imported complete with software and set up instructions on CD and installed with
the latest firmware.
They are £75 plus £5 insured next day postage, i offer full back up service by phone or email. i have 3 available at present .
Paul
Originally posted by zilspeed
Paulf
U2U if you like.
Thanks for the info that's good news
look out for a skyline power mk1 escort in a few month's
-----years
Jacko
