who can help me with megajolt running 1600 zetec on bike carbs cant get it started
where are you based and what are the symptoms?
Have you got a spark and fuel?
It should run without the MJ, just on the edis.
If you have spark and fuel check the plug leads are the right way round.
have you tried running it in limp home mode with just the EDIS?? If its not sparking try swapping the wires over on the crank position sensor as a first attempt
got spark got fuel its trying to start tryed with megajolt and with edis on its own
sounds like the leads are the wrong way around then. Does the engine turn over on the starter motor ok?? I found my trigger wheel was on 180deg out so it was trying to run on 2 cylinders (and turned over very slowly)
its wanting to start but just cant get that far engine is warm number one cyl is near the front pully to make sure
Mine actually ran on 2 cylinders but kept on stalling itself as it was firing in the wrong sequence. Try removing the leads one at a time to see if matters improve at all - you might find 2 are the wrong way around, daft as it may seem
Common fault is the wires to the crankshaft sensor round the wrong way. Worth swapping them over to check.
what would the symtoms be if they where the wrong way round apart from it dont run would it try to start
It wouldnt spark at all if they were the wrong way around. They are correct if its sparking ok at the moment.
whats the chance of the carbs been set wrong
Try squirting brake cleaner into the carbs when cranking , if it fires and runs for a few seconds then the ignition is working , if not the ignition may need attention. . Do the plugs get wet? could be too much fuel? . Coil pack should fire cyls 1&4 and 2&3 , might be worth changing the plug leads over if you haven't already tried that?
