I always come to this forum for real world advice rather than just repeats of other forums views...so here goes.
My son is looking to by an early 2003 Lotus Elise 111S.
It's done about 54K miles and looks in good condition in general. Had it all booked into a local Lotus garage for an inspection as we are buying
it privately...all sensible stuff. But now he is concerned about the chance of a head gasket failure, if it is on the way out then that's
easy-ish to spot. What we are wondering is how many K series engines in the Elise/MGF really do blow head gaskets? Looking at a few sites it looks as
if post 2001 Rover started to address the issue with steel locating pins and different gaskets which reduced the issue...
Are we really looking at a "yes it will blow anytime" or "Later models had the issue resolved"...?
Looking on the SELOC site there is a mixed bag of answers with some doom and gloom and others with 100K and no issues.
IIRC (I did a lot of reading at the time, but never owned one) Rover screwed up the cooling system design causing thermal shock and CTE issues, Lotus didn't.
There was an enormous load of rubbish posted on the net about this engines Rover made a few hanful of minor errors that added up and a resulted in
string of head gasket failures. Head gasket replacement on these engines is not the huge job altough some garages make it expensive by using more
parts than required.
The original cylinder gasket was a novel design that basically flawed it only stated giving problems when engine block design eas changed around
1992. The cylinder head gasket fitted to the version of the engine now produced in China is a complete redesign and provided the cylinder liner
heights are within limits it is a bullet proof fix.
There are some other minor mods that need to be applied --- fitting a Land-Rover TD5 thermostat and making sure a new specification cinlet manifold
gasket is fitted and a minor unoficial mod to the cooling system bleed venting.
Buy a VX220........but I am biased
Vauxhall VX220 Supercharged, 230bhp,65K miles,HPI clear (similar to Lotus Elise)
The problem is when you are 17 it has to be a LOTUS...😍
One thing to point out is the cam belt interval is either at 48k or 60k ---depending on the year the engine was built -- the design of the tensioner
and width of the belt changed. At 2003 it should be the later spec and be EU3 and have OBDII diagnostics.
Having OBDII diagnostics is a big plus.
When I was 17 it couldn't be anything but a Peugeot 205 GL because the insurance, purchase cost and running costs were outside my pocket and I was liable to kill myself in anything else. Lucky kid!
Hey,
I did a lot of research before I bought my S1 a couple of years ago. Mine was a 99' model with around 90k miles on it.
I never had any Head gasket issues. To be honest in the two years I owned the car (only sold as I bought a brand new Toyota GT86 as I was expecting my
first child) I never had any issues.
Bits are so cheap fo the K series I'd take the chance and replace the engine if needed later. You could always swap it for a Honda motor! Later
engines had better head gaskets and as long as servicing has been carried out regularly I'd say the higher miles wouldn't be a problem. I
did the cam belt and tensioner myself, it isn't as hard as you think. They are good cars to work on.
If your son is looking to get an Elise, I'd say go for it. I loved mine and even though I sold mine for a profit, prices are going up, so it
should be a good investment. Going to have to wait a while before I make money on my 86 lol.
Rob
