having read the ringer posts that keep being posted on here , what are you clasing as a ringer , some of you seem very quick to condemn , lock him up throw away the key, if you have a locost but on the log book it doesent say locost anywhere, but you call it somthing else is this a ringer in some of your opinions ,
If you see a car called a Bond Equipe that is a spartan body then the chances are its had the plate switched over google the two car types and you will see a distinct difference Its not a ringer if it has been rebodied on the original chasis Hop that makes sense
according to my brother who worked for west yorks police stolen vehicle squad for 5 years a ringer to them is a stolen vehicle that has had the identity ( chassis no and reg no ) of a legitimate vehicle applied to it..... make of that what you can !!
There are many reasons why something that appears to be incorrectly registered now could have been correctly registered at the time of registration.
There is a degree of ignorance or misunderstanding on here about the technicalities of the registration process and how it has changed over the years.
Anytime anyone sees anything that they don't understand, they start shouting ringer. It doesn't mean that the cars are ringers, or that they
aren't. Ringer is a misused term in these cases, incorrectly registered is the correct term. It doesn't help that you have to leave your
SVA/IVA certificate with DVLA when you register your car.
Perhaps someone can clarify something for me.
I built my own car using a single donor, I got an age related plate 'H' reg so looks like a 91.
the car was named by myself so I do understand how one can have what ever name you wish, I still called mine a Haynes Roadster, but!
The date of first registration on mine is 23/11/2009 when it was registered and it got a registration that was different from the donor.
Was this always the case in question?
Mine has a Special note in section 3
Rebuilt- Assembled from parts some or all of which were not new.
I guess things were different pre SVA/IVA, what was the rule back then?
Adrian
[Edited on 8-7-10 by AdrianH]
Adrian
Even pre SVA things were sometimes a bit random. My first car was inspected prior to MOT but just to check parts and not really it's construction, then, Chassis nunber was alocated, stamped, MOT and on the road.
The thing about the Bond/Spartan is it could have been very easily sorted out a few years back on the run up to the introduction of SVA.
Even now the Bond/Spartan could still retain its original registration as all that has changed is the body, the engine, chassis and running gear are
unchanged.
A ringer is as jase380 said.
All this sh1te about "ringing" kitcars is a bit tedious.
The rules have changed numerous times over the years to the state where we are now with the IVA where it's bordering on rediculous (IMO) as I
think that a lot of tintops wouldn't pass an IVA.
Wherever you go there are going to be a number of owners who take the pi55 but if you consider how many posts there are where a Locoster has got his
car through an IVA and bits have fallen off on the way home or been ripped out or changed as soon as possible for a nicer/better item
It makes me wonder when the kitcar police on here will start reporting one of us for changing the Sierra steering wheel and steelies for nicer
items
sorry rant over but can we use some common sense on this subject please
Oh and Andrew, my post wasn't a poke at you matey as you asked a good question but there seem to be some that keep banging this drum and
don't understand what a ringer is
I would say something like
Car registered as a Dutton on a Q but is actually and obviously a MK Indy or a Tiger or a Corbra.
Seen a few of that thing.
