Fortunately it stayed within the confines of the tunnel.
[img]
[/img]
Cant see the video at work, but I keep meaning to fit one of these!
a bit of a shock eh
i wondered what had gone on when i saw you pulled over!
Didn't realise thats what happened. It could have been a lot worse but would have been better with a catcher. What did it batter?
Easy to lose a leg or worse. Glad you got away with it!
Perhaps very lucky it was not far more catastrophic. Did it fail front or back?
Can I ask, who made your prop?
Sorry in advance for the hi-jack:
As a general question has there ever been any patterns identified with prop failures such as gearbox/diff combinations, alignment angles, prop
manufacturer etc? When i first built my car I made my own from a sierra prop. It was only ever meant to be temporary, in fact just for testing, but
ended up doing about 2,000 miles before taking the car off the road for other reasons. Other than a noticeable imbalance at high speed I never had any
problems with it.
I have always told myself I would replace it and now my rebuild is nearing completion I have been looking at my options. I am just rather concerned
that professionally manufactured props seem to fail all too often.
Rich
Sound doesn't do that justice, I was in the garage at the time my first thoughts was someone was going down the pit straight either scraping the
wall or upside down, it was very loud.
I had one fail at Cadwell top of the mountain, fortunately have a prop catcher in the tunnel, anyone thinking about it get one, flailing prop shafts
have no mercy.
the sound on that video reminded me of mine coming off. Horrible sound.
Lucky to get away with no injury and damage to car doesnt look to bad.
You will soon be back on the road.
That reminds me that I was going to do this over the winter. Thanks for sharing and I'm glad you're ok.
Now to find the threads and work out where I put the catcher - front or back?
[img][/img]
If it fails at the front it will flail till the wheels stop turning at whatever speed you are doing whereas the rear will be driven by the engine on tickover if you lift off.
If the front fails there is a small chance the prop can dig into the road ripping the rear axle/diff off and throwing the car violently in a random direction. Fit both.
Originally posted by Peteff
... whereas the rear will be driven by the engine on tickover if you lift off.
Or if you have enough wits about you, you could dip the clutch and it would stop completely?
I'd say if you can only fit one, a front one would be the best choice.
You were certainly lucky, I need to fit a prop catcher, but it keeps getting pushed to the back of the list along with the towing eye's and fire extinguisher. Was good to meet you at Oulton.
Mine came off at the front and smashed the clutch cylinder so no dipping that although it was irrlevant as it came off at the front. BTW it wiped out
the Brake master cylinder too so no foot brake either.
IIRC it took 2 water pipes, fuel line, chunk of block and all the engine bay / dash wiring too.
HO HO, that was a day to remember.
But it didnt take me or my 7 year old sat in passenger seat............
^^ your not wrong - but how long have you really got to get your foot on the clutch ?
...better to find a way to fit one at both ends![]()
[Edited on 12/11/2013 by mcerd1]
Very scary and a horible sound
i had mine snap at the front as i accelerated from 40 zone to 60 zone thankfuly no injurys to me or lisa
but the car was a right off as it hit a fuel line and burt to the ground
mine snapped at the front UJ nuckle
[Edited on 12/11/13 by Johneturbo]
Being new to kit cars I'd never really heard of this problem until now.
Has anyone used the ones that DAnST engineering sell?
http://www.locostbuilders.co.uk/viewthread.php?tid=156382
Seem cheap for the potential damage that could be caused..
I had one go on a Pilgrim Sumo Cobra replica once at the rear UJ. The thing hit the road and lifted the back of the car into the air slightly-
presumably this would have been rather worse if i was doing 70 rather than just 30mph at the time.
I put that experience down to the odd design of that car, the prop ran at wild angle to an off centre diff. Presumably in most kit though theres no
reason why a prop should fail any more frequently than in any other rwd car.
Originally posted by Not Anumber
Presumably in most kit though theres no reason why a prop should fail any more frequently than in any other rwd car.
I could see that would be the case if kit car prop shafts tended to fail on the welds where they had been cut and shut but they always seem to go on
the UJs though.
Is it to do with the joints having to handle significantly more power than they were built to withstand and is there any real solution ?
this is also on my to do list....... what sort of clearance should i allow to the prop ?
A prop catcher is one thing but what can be done to prevent failure. I dont see prop catchers having to be fitted to rwd road cars and i dont see
many rwd road cars suffering from prop failures.
Surely it's better to stamp out the disease rather than the minimise the symptoms ?
Ok, to answer a few questions.
1- It failed at the front.
2- It was a temporary prop with a rubber coupling which I do not like, but it was use that or miss the day.
3- I made it, but it wasn't my welding that failed but the rubber coupling. It's the seventh prop I've made over the years and
the first to ever let go.
4- It dented the tunnel tubes but only the lower ones, the upper ones escaped as the tunnel cover took the beating.
Punched a hole in the floor, you can see the newspaper undernbeath in the photo.
5- The wiring to the fuel pumps managed to get wrapped round the prop and pulled out from both ends.
But, hey, no damage to me
, the car is easily fixed.
I dont see prop catchers having to be fitted to rwd road cars and i dont see many rwd road cars suffering from prop failures.
A prop catcher is one thing but what can be done to prevent failure. I dont see prop catchers having to be fitted to rwd road cars and i dont see many rwd road cars suffering from prop failures.
There is the other type of failure, caused by imbalance/thin tubing apparently. This looks like ERW tubing.
The prop can start to whip and eventually fails http://www.locostbuilders.co.uk/viewthread.php?tid=122181
Prop catchers can also stop the diff falling out, when the diff mounts fail
Now that was a brown trouser moment
[Edited on 13-11-13 by 40inches]
I should imagine the failures seen in many kits and modified cars is due to builders (and suppliers) not understanding the need for the transmission
output and diff input flanges to be (at least almost) perfectly parallel, not having the means to set this accurately, or not making the shaft with
the couplings correctly phased.
Fitting the engine under the bonnet or dealing with other engine mounting issues normall takes priority over a correctly angled gearbox output. The
result of this is cyclic loading of the shaft (leading to fatigue) and vibration which may or may not be noticeable to the driver.
[Edited on 13/11/13 by matt_claydon]
you'd probably see more prop failures on tin-tops if everyone took them to the track for a good thrash every now and then![]()
prop catchers aren't needed as much on tin-tops mainly because your less likely to get injured when they let go (i.e. your not sitting right next to the thing with only a thin sheet of alloy and a few tubes to protect you
its more to do with the consequences of a failure than it is to do with the likelihood of failure
this says it all really![]()
home made / modified shafts that haven't been balanced will have more vibration and that could shorten there life, but even a brand new manufactured prop needs to be checked when the car is serviced to look for signs of damage or even just worn bearings or a lack of grease....
but that wouldn't help much in this case as it was the rubber coupling thingy...
[Edited on 13/11/2013 by mcerd1]
This is the rear catcher on my Fury...
I've similar one at the front but with different mounting points.
Even the big players can get it wrong
http://www.warrantyguide.co.uk/vehicle-recall-4264C6458146F814802570C10045C10B-nissan-pathfinder-and-navara-recall
Did your prop was balanced ?
I dont think it can happend if the prop is made on new parts welded as in the books says.
My prop was balanced with that rubber silencer a the front of the shaft (gearbox side)
left side of the picture
U 're right.
I will put a catcher maybe 2 just for case.
40 Inches looks good and I see it works
Just an update on our prop catchers - we now have new stock, revised to now be stainless steel as opposed to powder coated mild steel...
£9.99 per catcher.
Are they on your website? I couldn't find them
Originally posted by scudderfish
Are they on your website? I couldn't find them![]()
