Its amazing the negative responce I get to the following question....
Ring ring,,
"Hello, I need a corgi man to take out my gas fire and blank the pipe off ready for a log burner"
Responce...
"Ooooo, that sounds a bit complicated/ sorry fully booked/nobody to do it/too busy/can't promise a time" etc etc etc...
So, anybody competent want to come and take out my gas fire for me?
i'd just not tell them the bit about putting a log burner in.
had no trouble getting someone to take my old gas fire out
Could be opening a can of worms but just do it yourself. the gas man I had across the road said it is not against the law for me to blank a gas pipe that fed old boiler, if you can put a car together and drive it legally on the road one gas pipe ain't going to kill you just be careful. ps Corgi has been replaced by gas safe
Does your gas fire have a mild steel flue. Yuo will need to change it to one compatible with log burner due to high water content in the fuel, could that be putting them off?
if for example you took it out and capped it off you maybe able to find someone to test it for about £30 thats wat i did.
Last year I stripped my boiler down to change the gas valve - I bought a spray from b&q to test if the joints were good and hand no leaks- thats all a heating engineer will do.
You need to check then because some wood burners are not allowed in smokeless zones
Done that, well aware of what is and what isnt.
Ta,
isn't would more smokey than gas?
Originally posted by blakep82
isn't would more smokey than gas?![]()
