Help please
My Mum has just rang me to see if i can help with the heating boiler
The problem is
when she switches the switch to hot water the rads come on and she can't get hot water in the taps
The boiler is a Myson Velaire oil
Will it be the timer switch box going wrong or something else ie valve not working
Thanks for any help
Jacko
[Edited on 28/9/10 by jacko]
is there a 3 way valve somewhere in the system? That would be my first port of call
diverter valve if its a combi boiler
Sounds like it could be a fault with the diverter valve. Doesn't have to be a combi boiler.
Phil
Sorry to rant, but i think you mean PLUMBER there!!
Thanks for the info so far
Can the diverter valve be striped and cleaned / if so how do you do it
Jacko
Graham
Mine sticks now and again, It has a lever on top, I just turn the power of and operate it manually backwards and forwards a couple of times. Seems to
do the trick
Diverter Valve would be my first call...
Is this what i am looking for ? if so is looks like there is a manual override leaver
Jacko
It'll be the diverter valve. They're usually built into the boiler and not as big as the one shown (which is a zone valve).
Find the diverter valve. Give it a few taps, switch the boiler on and off, if all else fails call out a plumber
99% of the time these sx will be a stuck diverter valve though..... They're a common point to fail.
Mine (before going combi) wasn't built into the boiler. Shouldn't be too expensive to replace but unless you trust the ice pack systems will involve draining down the hot water tank & some of the radiator system.
mine did exactly the same it needed a new diverter valve cost about £45.00 and easy to fit once system had been drained down slightly
It may just be the motor on the actuator that needs replacing and not the whole valve......... Mines had about three new motors in the last 15 years
but still on the original valve.
Phil
