Can't find the answer from a search of the interweb but I know one of you will know the answer!
I found a little old Mustek DV4000 video camera at home whilst tidying up and I want to save a couple of videos onto my computer but I can't get
the cmputer to recognise the files.
They have gibberish names and I can't re-name / drag and drop or play them from either plugging the camera into the computer or putting the SD
card directly into the computer.
Any ideas?
They play on the camera but I can't do anything else with them......even delete them!
I downloaded some drivers but that hasn't helped the computer recognise the files.
did you get a disk with it, should have some software on it which will download it for you? Ulead or something like that. IIRC they produce asf files, ulead will convert these.
Dv 4000 driver download can be found on internet just type into google.
RD
No disk to use unfortunately. Tried downloading Ulead Video Studio but it has not helped, files still not recognised
you need to download and install the driver files for it first
RD
try VLC media player.....#
plays most formats, you are missing the codec to play whatever format your camera uses...
Search for the make of camera/age you have , then try and discover what codec is in use.
It should say what file type it is even if it doesn't recognise it.
For example a .wmv file will say it's a Windows video whereas (on mine) a .vob file says it's a vob file.
