Anyone know the going rate for a structural Engineer report is nowadays. i have decided to put a proper roof on my 40m2 conservatory and have been advised to get an Engineer to do his/her thing.
I've just knocked my conservatory down today. Initial plan was to add 7 stone pillars to place a roof onto, but after digging down beside the
conservatory to check foundation depth, I found almost no foundations. I think you should have close to 1m depth, 600mm wide for a single story
extension. I doubt many conservatories have anything more than a cursory helping of concrete foundation.
You could always underpin or fit a fake tiled roof.
Originally posted by deanspoors
I've just knocked my conservatory down today. Initial plan was to add 7 stone pillars to place a roof onto, but after digging down beside the conservatory to check foundation depth, I found almost no foundations. I think you should have close to 1m depth, 600mm wide for a single story extension. I doubt many conservatories have anything more than a cursory helping of concrete foundation.
again can't give the going rate for that type of engineer (I do structural steelwork myself)
but I can tell you to avoid WMA at South Queensferry - one of the other guys here used them on the advice of west lothian council and had nothing but
problems with them
The plan is to lift the existing roof and ring beam off and dispose, then fit a new ring beam that will sit on 2 brick pillars one at each end (these exist) and 2 new internal pillars these are at the house end, then build 3 new pillars outside the current footprint of the conservatory to support the new roof. the roof will be apex and hip ended timber trusses, boards and metrotiles.
