Bugger!
As mentioned on here earlier I'm busy making a rocket stove from 50mm ERW box section steel. Making the final cut today with the angry grinder I
managed to slice a pinky finger. A wash and a sticky plaster has held it for now, but a classic case of not paying enough attention to the tool and
making a mistake.
Quite rightly told off rather sternly by SWMBO and eldest son
Take care with power tools and stay safe people!
While cutting some 8mm steel strip to size the sparks managed to set my overall and t shirt alight. Wearing goggles I did not notice until I put the grinder down. No real damage done but I learned a lesson that day.
It happens and as you say it makes you learn. Hopefully you didn't suffer any injury, just some smouldering clothes.
What I would call an idiot rash, got a few myself
I was cutting a 3x2 box section frame into pieces, and after 2 cuts the cut tightened breaking the 9" blade.
the angry grinder spun round out of my hands, I was saved by the plug pulling out and the Dickies padded overalls
Angry grinder
We all do a half assessment of whether to wear protective gear or not, usually failing to fully take into account of consequences if it goes wrong but
just take probability of it going wrong.
To illustrate many of us would quite happily walk along 6 in wide bean 2 ft off the ground but would be less happy doing the same on a beam 1ft wide
but 50ft above ground.
You are less likely to fall off the wider beam but there is a big difference between falling 2 or 50ft.
Now I always put on a pair of protective glasses when drilling, it's not happened yet and even though the chance getting a piece of metal in the
eye is very low, the consequences of it happening could be loss of sight.
Reading this I may start wearing protective gloves when holding Mr angry.
As shown by the op, no matter how careful you are, poo happens.
I seem to do my left forefinger knuckle when it happens, I could see the knuckle joint the first time, very little blood.
I now keep a tube of superglue handy just in case I do it for a third time
I find I'm less cautious with an angle grinder when I wear ear protectors - it just seems safer when it's not screaming in my ears - a false sense of security I know!
I was cutting some 3mm aluminium sheet a couple of weeks ago, with the jigsaw. Lots of stop/start making cuts, as I kept offering the piece up to
where it's going on the car. I started off wearing safety glasses (and usually I am reasonably good at wearing PPE), then at some point I took
them off and didn't put them back on. A couple of cuts later and a shard of alu came up and hit me in the eye. Lucky escape, no damage done, but
it just underlines why we should be wearing the protective stuff all the time.
I do with the angle grinder as I had a disc break a while ago - and part of it whacked straight into the visor I was wearing - but obviously I felt
too safe with the jigsaw!
A stupid trick I've done 2 or 3 times in my building saga is to wear all the protective gear while doing a piece of work... then, when I think
I've finished and taken all the gear off, I spot something that needs "just a touch" with the angry grinder.
You guessed correctly - that's when the grinder jumped or kicked back...
With me - finished for the day, all gear off, clearing up, picked up the grinder which immediatly switched itself on, bugger, 4 hours in hospital
later came home. Took the grinder apart to find due to use the power cable had fractured making intermitent connection and had connected as I picked
it up. Cable shortened and fixed.
Despite wifes call to bin it still have the grinder and also its new replacement as ordered by the boss (wife)
Now have two grinders :-)
BUT these things are the most dangerous tool any of us will ever use and we should all be aware of that and be as safe as we can!!!!
Never like angle grinders, I still don’t have one at the minute, accidents
Happen with them far to quickly!
I've also set fire to stuff by not watching where the angry grinder's sparks were going - done that a few times... done the same with the
sparks from welding...
Nowadays I *try* to ensure that there's nothing inflammable downstream of the grinder or welder. But it always seems to be the "quick
one-minute job" that causes the problems.
My friends used to ask me on a friday "what have you set fire too this week" as for a few weeks running i set fire to something. The
favourite story was when i held the grinder infront of me cutting metal held in a vice. The sparks hit my padded aldi pollyester jumper.....
I thought it was getting a bit warm but finished the cut.
So then discover i'm wearing welding gloves (due to mr angry grinder) and my groin is on fire ...... its a very strange experience trying to hit
yourself in the groin to put out a fire. You don't want to hit yourself but know you need to.
Luckily thats the worst i've done with the angry grinder. I do tend to be quite good with the ppe. I have managed to give myself a nasty burn by
welding a long seam, taking the gloves off and then leaning over and holding my weight against the reverse seam to check how i'd done. I then had
to push against the hot steel burning my hand to stand up.
Years ago on this forum i remembered someone posting about a drill bit breaking and getting embedded into the goggles they were wearing. The gentleman
only had sight in one eye. It embedded infront of his good eye. That makes me wear goggles a lot more than i used to, especially with small drill bits
(but rarely with larger ones).
Stay safe everyone, this is supposed to be a fun hobby.
I am generally quite happy using a 4-1/2" grinder, but am a lot more nervous with the 9"
On the one hand I'm glad to hear it's not just me.
On the other it simply highlights to me that accidents happen to all and we ALL have to take better care of ourselves.
As before, please look after yourselves and think ahead. Accidents happen so quickly and consequences can be so bad!
I bought myself a winter workshop coat from a local Army surplus store - full NATO spec ex Austrian army, warm comfortable, goretex lined, the
works.
Too good for the workshop really and it turned out to be the perfect coat for winter bird watching. Now it has a big black hole around the groin
thanks to some careless cutting of sheet steel.
Some years ago I was grinding with my son watching when he started hitting me because I was on fire. I was totally unaware on both occasions.
My (cant remember the make) grinder has a lock-on option (seriously?!) which locks when you push/use the grinder.
I had a cup brush fitted (lovely wire-flinger, good for burying wire ends in your face/arms/fingers as a normal hazard). Caught on my sleeve, while it
had inadvertently locked on. It wound up my sleeve and buried itself in the back of my left hand. As letting it go didn't stop it, the only
option I had for preventing further damage was to hold it as tight as possible to try to jam it.
Removed a 50p piece area of flesh down to the bone on my hand and scuffed up my arm, had to pick bits of wire out the back of my hand and it was
purely good luck that it got me between two ligaments or I'd have lost function of my left thumb and forefinger.
If you can find the lock-on option and snap the catch off, do so.
If you can wear leather gloves ALWAYS do so.
I'm very lucky it was limited to that damage and it was my own stupid fault, but why the hell do they have a lock-on button?
A decade later it looks like this...no hospital visit (all the digits moved, seemed no point troubling the good folk at the hospital and after 3 weeks
it had healed over).
Angry Grinder
[Edited on 12/5/20 by coyoteboy]
I had a cup brush fitted (lovely wire-flinger, good for burying wire ends in your face/arms/fingers as a normal hazard). Caught on my sleeve, while it had inadvertently locked on. It wound up my sleeve and buried itself in the back of my left hand. As letting it go didn't stop it, the only option I had for preventing further damage was to hold it as tight as possible to try to jam it.
Removed a 50p piece area of flesh down to the bone on my hand and scuffed up my arm, had to pick bits of wire out the back of my hand and it was purely good luck that it got me between two ligaments or I'd have lost function of my left thumb and forefinger.
A decade later it looks like this...no hospital visit (all the digits moved, seemed no point troubling the good folk at the hospital and after 3 weeks it had healed over).
Angry Grinder
In my opinion small grinders need to be able to be locked in the on position, they are awkward to use in some situations if you have to hold them in a certain way to keep the switch pressed.
A couple of my air tools have a nice and safe arrangement - a long lever that's easy to keep on, but with a latch that needs to be pushed aside
before you can pull the long lever. It's not easy to pull the lever accidentally, but reasonably easy to operate the safety latch.
Here's an example I plucked off the Machine Mart website - the arrangement of the operating lever is clear.
"I am generally quite happy using a 4-1/2" grinder, but am a lot more nervous with the 9"
I am exactly the same, the 9" seems to be a bit over the top for most of the jobs ive done, so its rarely used
I will add, that all of us have done something silly using workshop tools at some point, in fact I am very surprised that I appear to have all of my
digits, and eyes, quite incredibly !!
The most painful one, all though there have been a few, was soldering a new rectifier into my Suzuki 250
I had the garage vice on the seat to hold everything in place, and for some bizzare reason picked up the soldering iron on the HOT metal, not the
handle !!!
so, that's not the worst bit !, having jumped in the air with burns on my hand, the vice (heavey record vice) falls of the seat, and lands on my
left foot
I broke my foot so bad, at one point amputation was considered, and a few weeks in hospital, and in plaster but no pins or plates,
and a lot of time recovering, all seems to be ok, but now in the winter, left foot aches so badly I have to take painkillers
And then the story of me breaking my arm in two places putting a new fence panel in, we wont go there, as my arm still has problems 5 years later !
steve
Didn't mention before, my angry griner is 4/5" not 9".
I nearly lost my thumb to a grinder a few years back.
SoreThumb
SoreThumb2
I don't tend to have grinder accidents these days even though the shield is removed, the handle is never fitted and I just fit & remove the
disks by hand, I do wear safety glasses most times (depends on what I'm doing or if I can be bothered looking for them) but have learnt to hold
it so that if it goes bang I'm not in the firing line. I did have one burst into flames once, like foot long flames coming out the vents god
knows what happened there but it was just toast. I did stand in amazement when one of my friends who borrowed it to cut of his rear silencer and had
all the safety gear on (cos he knows what he's doing...) aimed it so that the sparks fired straight back at his face, I was like what the f£ck
are you doing you nutter!
[Edited on 2/6/20 by Mr Whippy]
Always think about where the sparks and grinding waste is going to go. It has the potential to make a right mess of things!
Did this a fortnight ago
Then to add insult to injury I fell of a ladder a couple of days latter taking the skin of it. Only thing I had to hand to
clean it with was 70% hand sanitizer
Welding my water rail I got it caught I. My welding gauntlet. Flinched and flicked up the inside of my arm.
